Gear oil
Mobilgear 600 XP Gear Oil series is engineered to deliver wear and corrosion protection for gearboxes.
Mobilgear 600 XP Gear Oil series is engineered to deliver wear and corrosion protection for gearboxes. The gear oil surpasses industry specifications such as Flender BA Table 7300 A, DIN 51517 Part 3 and AGMA 9005 E02. It is formulated to help control micro-pitting, and is designed to significantly reduce the formation of oil degradation by-products that often lead to frequent oil changes.
ExxonMobil Corp.
