Gauge range marking system
The marking system makes it easy and visual to know if everything is performing correctly.
Gauge Range Marking System are translucent self-adhesive sheets in red, yellow and green. The system makes it simple to mark gauges so the operators can see if equipment is in the proper operating range. The gauge marking system comes pre-cut, with the most common sizes 1", 1-1/2", 2", 2-1/2", 4" plus full sheets to customize to your needs. Gauge Range Packs include: three colors: red, yellow, green, and 5-year outdoor transparent marking vinyl.
5S Supply
