Gas regulator
The model 3011/3041 blanket gas regulator product line now includes ½-inch connection sizes. This provides a cost-effective solution for lower volume processes that require lower flow capacities. The regulator features direct acting, modulating valves with a force multiplying linkage, single-stage regulation from 200 psig to 0.
The model 3011/3041 blanket gas regulator product line now includesed piston design. It is offered in stainless steel and other materials by request and with NPT or flanged connections for all sizes, with optional sanitary fitting or quick disconnect connections for the half inch size.
Groth Corp.
