Gas chromatograph for natural gas measurement applications
Emerson Process Management's Danalyzer 370XA Gas Chromatograph (GC) is designed for continuous online analysis of natural gas for applications and has a module that can be replaced in the field.
Emerson Process Management’s Danalyzer 370XA Gas Chromatograph (GC) is designed for continuous online analysis of natural gas for applications such as custody transfer, power generation, and burner fuel/air ratio control. The Danalyzer 370XA also provides a C6+ analysis and an intuitive local operator interface (LOI), all of which come standard.
Another feature is the Maintainable Module, which incorporates the analytical components in an easily removable module. The Maintainable Module can be replaced in the field in approximately two hours (including warm-up and purge), and can be maintained at the component level. Software assistants on the full-color LCD local operator interface reduce the need for specialized training by providing a step-by-step walk through of common operational and maintenance functions such as changing calibration gas, auto-valve timing and module replacement. The Danalyzer 370XA can be pole-mounted, wall-mounted or floor-mounted. No shelter is required for most environments.
– Edited by CFE Media. See more Control Engineering diagnostic and asset management products.
