Fused coordination panel
The Coordination Panel provides a simple and time-saving solution for circuits that require selective coordination. The panel is UL Listed to UL67 Panelboards and UL50 Enclosures, and features 120/208 V or 277/480 V main lugs; a 100 kA short circuit rating; an MLO 200 A main bus rating; branch circuit breakers coordinated with Class CC fuses (sold separately); Class CC fuse holders with built-i...
The Coordination Panel provides a simple and time-saving solution for circuits that require selective coordination. The panel is UL Listed to UL67 Panelboards and UL50 Enclosures, and features 120/208 V or 277/480 V main lugs; a 100 kA short circuit rating; an MLO 200 A main bus rating; branch circuit breakers coordinated with Class CC fuses (sold separately); Class CC fuse holders with built-in blown fuse indication; ground and neutral bars; and a Type 1 (NEMA) enclosure.
Littelfuse : www.littelfuse.com
