Food grade HMI solution
The eTOP4FOOD has been designed and proven to solve the industry wide problem of HMI failures and less effective alternative HMI cleaning procedures.
The eTOP4FOOD has been designed and proven to solve the industry wide problem of HMI failures and less effective alternative HMI cleaning procedures. With the eTOP4FOOD no longer is the HMI required to be shielded from high temperature, high pressure cleaning. Features include stainless steel bezel 316/1.4401, IP69K, food-compatible basket, PCAP touchscreen that can be operated with gloves for food areas, and food standard sealing complaint with FDA 21 CFR 177.2006.
Electromate
