Fluid Handling
Software troubleshoots gas piping Pipe-Flo for compressible fluids is an advanced piping network software for industrial gas piping systems.
Pipe-Flo for compressible fluids is an advanced piping network software for industrial gas piping systems. It is the perfect tool to design, analyze, and troubleshoot piping networks used in process and industrial gas applications. A clear picture of how pipeline components work allows the user to make changes to the model and see the effects. Engineered Software, Inc.; www.eng-software.com
For more information, circle 139 on card
Pipe insulation removes condensate
PermaWick fiberglass, below ambient pipe insulation allows vapor to migrate to the cold pipe where it condenses and is wicked away to the underside of the insulation. There it evaporates, leaving the insulation dry and its thermal qualities intact, ensuring proper insulation performance and condensation control. Knauf Fiber Glass GmbH; www.knauffiberglass.com
For more information, circle 146 on card
System monitors emergency valves
ValvGuard testing and monitoring system for emergency valves allows plant operators to intensify surveillance of safety shutdown valves by checking them on-line as often as desired. The result is a higher level of diagnostic coverage and assurance that ESD valves will operate if an incident occurs. It can be used up to SIL 3. Neles Automation; www.nelesautomation.com
For more information, circle 203 on card
Couplings allow easy removal
Uniflex union pipe couplings have a gasketed seal and unique construction that provides significant energy cost savings, reduced labor and inventory cost, zero leakage, and ease of installation and removal. Zero clearance fit means there is no need to spring pipes apart when making repairs. Nicholson Steam Trap; www.nicholsonsteamtrap.com
For more information, circle 212 on card
