Flowmeter measures blended waste and natural gases for co-gen power
The ST98 flowmeter is suitable for service in biogas and natural gas, as well as numerous other process gases, hydrocarbon mixed or dirty gases and plant compressed air and HVAC systems.
By Fluid Components International LLC January 6, 2016
The ST98 air and gas flowmeter measures the blended waste gas and natural gas necessary to keep co-generation power systems up and running. The ST98 provides direct mass flow measurement without the need for additional temperature, pressure sensors, or density calculating devices. It is suitable for service in biogas and natural gas, as well as numerous other process gases. ST98’s thermal mass flow sensing element is constructed with two all-welded 316L stainless steel thermowells. The ST98 meter’s transmitter converts the differential temperature signal to a standard 4 to 20 mA output signal. The ST98 is unaffected by plant vibration.
www.fluidcomponents.com
