Fix hoses quick
Crimp Tool performs fast and easy hose repairs on any low-pressure air or water system hose assembly up to 300 psi. It uses durable brass collars, which fit around a hose and barbed fitting assembly.
Crimp Tool performs fast and easy hose repairs on any low-pressure air or water system hose assembly up to 300 psi. It uses durable brass collars, which fit around a hose and barbed fitting assembly. The portable tool requires no additional hardware for operation. Simply place a hose, fitting, and collar assembly into the tool and hand-tighten to securely crimp the collar in place.
NewAge Industries, Inc.
Circle 255
