Fiber laser
The F-series fiber laser is available in 10- and 20-W versions that combine YAG technology with fiber optics to accommodate precision marking.
The F-series fiber laser is available in 10- and 20-W versions that combine YAG technology with fiber optics to accommodate precision marking. Capable of printing bar codes, logos and technical drawings, the laser can mark on materials ranging from flexible foil and plastics to metal in either static or dynamic, on-the-fly applications. The laser operates with a handheld terminal, touchscreen or PC, and its YAG fiber tube requires no maintenance or consumables.
ID Technology , a div. of Pro Mach
www.idtechnology.com
