Ferrous debris monitor
The ANALEXfdM Plus detects and measures ferrous wear debris in lubricating oils, hydraulic oils and greases – regardless of particle size.
The ANALEXfdM Plus detects and measures ferrous wear debris in lubricating oils, hydraulic oils and greases — regardless of particle size. The monitor delivers quick data to aid in the consistent management of oil condition samples and comes with increased software functionality, allowing the user to test from different types and sizes of sample vessels. The unit can operate on a 12-volt power supply, which helps provide instrumentation to users in the field.
Kittiwake
www.kittiwake.com
