Faceshields attach to protective hats
Foldback Faceshield Frames are compatible with slotted or non-slotted helmets. They attach to helmets with a channel that fastens to the brim and an elastic or spring band that wraps around the back of the helmet.
Foldback Faceshield Frames are compatible with slotted or non-slotted helmets. They attach to helmets with a channel that fastens to the brim and an elastic or spring band that wraps around the back of the helmet. Frames are compatible with a full line of visors and are available in plastic or metal.
MSA
Circle 389
