Extended temperature ballast for outdoors
B4CF1 Cold-Pak extended-temperature fluorescent emergency ballast for compact lamps is ideal for outdoor egress applications. The ballasts are designed for temperatures ranging from -4°F to 131°F and are suitable for use in damp locations. Applications include sealed and gasketed fixtures, bollards, sconce and outdoor egress applications.
B4CF1 Cold-Pak extended-temperature fluorescent emergency ballast for compact lamps is ideal for outdoor egress applications. The ballasts are designed for temperatures ranging from -4°F to 131°F and are suitable for use in damp locations. Applications include sealed and gasketed fixtures, bollards, sconce and outdoor egress applications. The built in heater warms battery to proper charging temperature. The Bodine Co. : www.bodine.com
TO VOTE, WRITE 122 ON BALLOT
For more information, write 122 on card
