Evaporative cooling unit
The Hurricane portable evaporative cooling unit utilizes high-efficiency cooling pads and provides 67-gallon water capacity and 14,500 CFM
The Hurricane portable evaporative cooling unit utilizes high-efficiency cooling pads and water to naturally cool up to 3,500 sq ft and lower temperatures up to 30 F. The unit’s design provides 67-gal water capacity and 14,500 CFM. The Hurricane requires only 11.4 amps for pump and motor operation. It has a dual water fill with hose hookup or manual tank fill and it doesn’t require chemicals or refrigerants to produce cool air output. Additional features include a digital control panel with easy touch buttons for operation and status displays.
Port-A-Cool
www.port-a-cool.com
