Environmental monitoring system
The viewLinc environmental monitoring system leverages wireless communications capabilities in order to utilize logging devices that communicate in obstructed environments.
The viewLinc environmental monitoring system leverages wireless communications capabilities in order to utilize logging devices that communicate in obstructed environments. The signal strength between network access points and data loggers can travel over 100 meters indoors. It is ideal for use in applications such as pharmaceuticals, temperature, humidity, museums, galleries, IT server rooms, and other high-value assets that are affected by environmental conditions. It provides trends, alarming, and customized reporting that ensures accurate environmental information.
Vaisala
