Energy chain cable carriers
Energy Chain cable carriers and Chainflex continuous-flex cables are designed for use in extremely tight spaces. The compact versions of the line of automated machinery components are particularly suitable for packaging applications and come in any shape and size, The E2 micro series is manufactured for lightweight, quiet and low-cost applications.
Energy Chain cable carriers and Chainflex continuous-flex cables are designed for use in extremely tight spaces. The compact versions of the line of automated machinery components are particularly suitable for packaging applications and come in any shape and size, The E2 micro series is manufactured for lightweight, quiet and low-cost applications. It’s available with an inner height as low as 0.20 inches and as a zipper chain for fast, easy access to cables and hoses. Zipper chains have interconnected lids that are pulled back like a zipper, removing the top section of the carrier. Chainflex CF98 continuous-flex cable has a recommended bend radius of four times the outer diameter and is equipped with unique alloy conductors that have higher tensile strength than standard copper. Chainflex continuous-flex cables are designed to withstand the stress of tight-bending radii to deliver longer extended life.
Igus, Inc.
