Embedded PCs
The Compact CX8190 embedded PCs is ideal for Ethernet communication.
The Compact CX8190 embedded PCs is ideal for Ethernet communication. The embedded PC is equipped with an Ethernet port and a 2-port switch for real-time Ethernet of EtherCAT Automation Protocol (EAP). It features a 1-second UPS for storing data, a 512 MB microSD card which can be extended up to 8 GB, and an operating temperature range from -25 to 65 C.
Beckhoff Automation
