Embedded intelligence increases photoelectric sensor reliability
New IP69K-Rated Sick W12-3 photoelectric sensor with rotating connection withstands washdown environments; Sick OES3 ASIC, provides smart background and foreground suppression.
10/14/2009
Sick W12-3 photoelectric sensor, rated IP69K,  withstands washdown environments, has rotating connections, and smart background and foreground suppression.
Sick W12-3 photoelectric sensor uses Sick's third generation application-specific integrated circuit (ASIC), the OES3. The new ASIC delivers what Eric Simmons, Sick product specialist, describes as "best-in-class background and foreground suppression." He says the OES3 was developed through years of research to determine the best ways to detect an object at its true location while maintaining a good black / white shift and the ability to ignore possible interference, such as high frequency lights, another sensors light source, false outputs caused by reflections from shiny targets beyond the sensors sensing range.
Application challenges
The Sick OES3 ASIC addresses background and foreground suppression, Simmons says, in the following ways.
- Black/white shift: Black absorbs much more light than a white target, Sick uses the Kodak color scheme white = 90% reflectivity and black = 6% reflectivity.
When a target changes color (either on the same package or after a recipe change) sensors may not be able to detect the differing colored targets. This would cause the sensor's output to turn off and then back on which must be handled by software or the sensor needs to be readjusted. W12-3 with OES3 technology can detect the multicolored object without the sensor's output turning off and on or having to readjust the sensor when products change color.
- Stray reflections: Sick sensors using the OES3 chip can to ignore stray reflections beyond its sensing range that may reflect back and flood its receiving elements. This could be caused by someone walking past with a reflective vest, a window being opened beyond the sensors sensing range, a shiny object moving beyond the set point, and similar environmental challenges.
Sensor details
Sick, manufacturer of sensors, safety systems, machine vision, and automatic identification products for factory and logistics automation, offers IP69K-rated W12-3 Photoelectric Sensors for harsh wash down environments. These sensors use Sick's third generation custom ASIC (application-specific integrated circuit-see details, left) that incorporates OES3 technology to provide exceptional background and foreground suppression at an extended range. The OES3 chip contains proprietary technology that enables the W12-3 to ignore stray background reflections, detect multi-colored / shiny objects, and provide high immunity to ambient light.
The W12-3 is the newest high-performance sensor in the W12 Photoelectric Sensor Family. Both non-programmable and potentiometer versions of the W12-3 feature an IP69K-rated metal housing (made of die cast zinc) that enables the sensor to withstand harsh cleaning agents in food and beverage, packaging and pharmaceutical environments. In addition, the W12-3 offers multiple mounting options (dovetail base and back mount, flanged-base through hole, diagonal through holes) and a 270° rotating connection for flexible installation.
- High frequency lighting: Energy efficient, high-frequency (HF) fluorescent lighting can wreak havoc on photoelectric sensors. Embedded intelligence recognizes when a HF light is present and will not "chatter."
- Another sensor's light source: Cross talking occurs when two sensors are pointed at one another. Sensors are modulated to a unique frequency but may have instances when they are nearly in phase or a pulse is in the same modulation as its own light source, because of this similar phase the sensor thinks that it is seeing a target within its sensing range.
These sensors can recognize when another sensor's light source is nearly the same modulation and adjust.
How the ASIC design helps
Four key features in the OES3 chip, Simmons says, meet customer needs:
- 16 element logarithmic array: The OES3 sensor uses a 16 element logarithmic receiver array that is segmented from bigger to smaller sizes. This logarithmic design will allow high-performance background suppression at an extended range, as a target is moved farther away from the sensor the light returning to the receiver gets smaller. With normal receiver elements, the sensor has trouble distinguishing between background and target.
- Active area management: The OES3 chip has a second sender LED, called the Pilot LED, that sends out light offset from the main sender LED by 4 micro seconds. The Pilot LED is a diffused light that is designed to detect any potential false reflections caused by a shiny/glossy targets outside the set sensing range. Reflections returned from the Pilot LED are recorded by the OES3 ASIC, and if the stray reflection is returned from the main sender in the same location and intensity as the Pilot LED the sensor's output will not become active. False trips caused by stray reflections (such as reflective vests, windows, shiny / glossy backgrounds) is virtually eliminated because of the active area management feature.
- Self adjusting light spot: It has the ability to adjust the light spot based on the reflectivity of the target it is detecting. If the target presented to the sensor is highly reflective and the receiver elements become flooded with light the sensor will tune down the intensity of the sender LED to compensate for the amount of light being received so that the true location of the object can be detected. If the target presented to the sensor is very dark, the sensor will tune up its intensity so that enough light is being received by the receiver elements to detect the object's actual location.
- Passive area management: The sensor can ignore high frequency lighting and one other sensors light source. It does this by checking the area for the HF lamp when it is not looking for its own modulated light source. When the sensor does look for its own light, because of modulation, it will know that there is a HF light causing interference and will filter out the noise caused by the HF light.
Read a Control Engineering discrete sensing feature article on proximity, inductive, laser sensors, " Proximity Sensors: How to Choose, Use Them ."
- Edited by Mark T. Hoske, editor in chief, Control Engineering www.controleng.com
Read more about sensors at the Control Engineering industrial sensor channel .
2015 Top Plant: Phoenix Contact, Middletown, Pa.; 2015 Best Practices: Automation, Electrical Safety, Electrical Systems, Pneumatics, Material Handling, Mechanical Systems
A cool solution: Collaboration, chemistry leads to foundry coat product development; See the 2015 Product of the Year Finalists
Raising the standard: What's new with NFPA 70E; A global view of manufacturing; Maintenance data; Fit bearings properly
Special report: U.S. natural gas; LNG transport technologies evolve to meet market demand; Understanding new methane regulations; Predictive maintenance for gas pipeline compressors
Cyber security cost-efficient for industrial control systems; Extracting full value from operational data; Managing cyber security risks
Drilling for Big Data: Managing the flow of information; Big data drilldown series: Challenge and opportunity; OT to IT: Creating a circle of improvement; Industry loses best workers, again
Migrating industrial networks; Tracking HMI advances; Making the right automation changes
Understanding transfer switch operation; Coordinating protective devices; Analyzing NEC 2014 changes; Cooling data centers
Upgrading secondary control systems; Keeping enclosures conditioned; Diagnostics increase equipment uptime; Mechatronics simplifies machine design
After almost a decade of uncertainty, the confidence of plant floor managers is soaring. Even with a number of challenges and while implementing new technologies, there is a renewed sense of optimism among plant managers about their business and their future.
The respondents to the 2014 Plant Engineering Salary Survey come from throughout the U.S. and serve a variety of industries, but they are uniform in their optimism about manufacturing. This year’s survey found 79% consider manufacturing a secure career. That’s up from 75% in 2013 and significantly higher than the 63% figure when Plant Engineering first started asking that question a decade ago.
Read more: 2014 Salary Survey: Confidence rises amid the challenges
This article collection contains several articles on the vital role that compressed air plays in manufacturing plants.
