Electronic cleaner
ElectriCorr VpCI-238/239 is powerful electronic cleaner, provides instant, long-term, multi-metal corrosion protection.
ElectriCorr VpCI-238/239 is powerful electronic cleaner, provides instant, long-term, multi-metal corrosion protection. It is designed to fight corrosion of complex, sensitive electronic and electrical equipment.
The product forms a thin, fast-drying, non-sticky corrosion inhibiting film effective against the most aggressive and polluted environments by displacing moisture and protects most metals and alloys normally found in electronic applications.
ElectriCorr VpCI enables longer equipment life and minimized field service as well as enabling vapor phase protection in vented or unvented enclosures and can be safely used with most plastics, elastomers, and other non-metallics.
Conforming to NACE Standard 0487-2000, NACE TM 0208-2008 it’s approved for US military and NATO use under NSN 6850-01-413-9361.
Cortec’s EcoSonic
www.cortecadvertising.com
