Electrodeless conductivity sensor
The Foxboro FT10 electrodeless conductivity sensor is designed for use in high purity measurement of low-volume liquid applications. The device is equipped with virgin PFA Teflon-wetted materials and has leak-free weld connections that eliminate internal threads, O-rings and gasket seals. The device is available in ½-, ¾- or 1-inch sizes, with a housing measuring 7 by 5 by 2 inches.
Invensys Process Systems : www.foxboro.com
