Electric Motors, Drives, & Controls
11/10/2004
Motor tester finds early faults
ALL-TEST PRO 31 electric motor tester performs a rotor test in less than 3 min, checks winding conditions to detect turn-to-turn or coil-to-coil faults early, determines phase balance, detects open windings, finds FDW or cable problems, and incorporates megohm meter with choice of 500 or 1000-V test and 0.00%%MDASSML%%500 MV range. Instrument works on ac and dc motors of virtually any size.
BJM Corp. : alltestpro.com TO VOTE, WRITE 60 ON BALLOT For more information, write 60 on card
Meter detects broken rotor bars
CSMeter is a handheld instrument for online detection of broken rotor bars in squirrel-cage induction motors. Instrument provides on-the-spot diagnosis using advanced algorithms that guard against false indications. It is portable and requires only a current probe to clamp around one of the motor's main leads or around the secondary side of a main CT. Stores data for up to 29 motors.
Iris Power Engineering, Inc. : irispower.com TO VOTE, WRITE 92 ON BALLOT For more information, write 92 on card
Soft starter reduces motor wear and tear
Altistart 01 electronic soft starter enhances starting performance by ensuring a smooth and controlled start for 1 and 3-phase asynchronous motors, while providing torque surge suppression during starting and stopping operations. DIN rail mountable soft starter is compact, highly functional, includes removable terminal blocks, and is offered in 3 levels from 1/4 to 75 hp.
Telemecanique : us.telemecanique.com TO VOTE, WRITE 151 ON BALLOT For more information, write 151 on card
Robot optimizes tight spaces
PowerScara is a compact, low-cost robot designed to fit into tight workspace configurations and to mount to existing station frame structure. Size of the controls has also been reduced to fit within a single slot of a 19-in. rack-mount cabinet. The drives/amplifiers are built into the robot arm, further reducing space requirements. Absolute encoder system eliminates need to reference.
Bosch Rexroth Corp. : boschrexroth-us.com TO VOTE, WRITE 159 ON BALLOT For more information, write 159 on card
Brake motor resists inverter spikes
Super-E brake motors are NEMA Premium efficiency, and feature inverter spike resistant (ISR) magnet wire, and long-life spring-set brakes with 230/460-V coils connected inside motor conduit box to allow separate connection if used with adjustable speed drive (ASD). Brake is mounted opposite drive end to provide NEMA standard BA dimension and conversion to C-face design.
Baldor Electric Co. : baldor.com TO VOTE, WRITE 157 ON BALLOT For more information, write 157 on card
2016 Engineering Leaders Under 40; Future vision: Where is manufacturing headed?; Electrical distribution, redefined
The digital oilfield: Utilizing Big Data can yield big savings; Virtualization a real solution; Tracking SIS performance
Applying network redundancy; Overcoming loop tuning challenges; PID control and networks
Driving motor efficiency; Preventing arc flash in mission critical facilities; Integrating alternative power and existing electrical systems
