Dual mode LED tube
The Duluxe LED Tube is designed for long-term maintenance and runs at 18W and provides up to 122 lumens per watt.
The Duluxe LED tube is designed for long-term maintenance applications and is compatible with both electronic and magnetic ballasts. It can also work on 120 to 277 V line voltage which means there is no replacement needed when the ballast fails. The 4 ft. tube runs at 18 W and provides up to 122 lumens per watt. The tube is also compatible with motion controls and sensors for even greater energy savings. The Duluxe LED Tube is constructed with shatterproof, coated glass and provides a 300° beam angle with a proprietary optical design for light distribution. The dual-mode tube does not contain any lead, mercury, or toxic gases which makes it an ideal solution for food service and healthcare applications. The Duluxe LED Tube is available in 4000 and 5000 K.
HyLite LED Lighting
