Drum hot box loads with pallet jack
Sahara hot box sits flush with the ground for loading with a pallet jack. It is designed to heat four 55-gal. drums on a single pallet with precise digital temperature control from room temperature to 350 F. The unit is completely assembled.
Sahara hot box sits flush with the ground for loading with a pallet jack. It is designed to heat four 55-gal. drums on a single pallet with precise digital temperature control from room temperature to 350 F. The unit is completely assembled. Simply set in place and connect the power supply.
Benko Products, Inc.
www.benkoproducts.com
Circle 376
