Drain cleaner uses auto feeds
K-40 drain cleaner features a guide hose power feed accessory that does away with whipping cables and leaves the job site cleaner.
K-40 drain cleaner features a guide hose power feed accessory that does away with whipping cables and leaves the job site cleaner. The retractable cable self feeds using the auto feed lever, and goes back into the machine using the reverse mode so that hands never have to touch the cable. A unique inner drum design virtually eliminates cable flip over and drum leakage.
Ridge Tool Co., Ridgid/Kollmann; www.ridgid.com
TO VOTE, WRITE 72 ON BALLOT
For more information, circle 46 on card
