Door vending solution
Automated inventory vending systems to be unveiled at IMTS.
The TX750 feature’s a flexible, rolling dual-tambour-style door that dispenses square boxes and other maintenance, repair and operations (MRO)-related items with no repackaging required. The TX750 is ideal for maintenance, plant services and manufacturing environments that have a need to dispense large, square or rectangular-shaped products not supported by traditional helix/coil machines or carousel type machines that use pie-shaped bins.
The TX750 also features a clean user interface, which takes maximum advantage of the bin density and flexibility while allowing a user to configure the machine on-the-fly using a native bin assignment process that is quick and intuitive.
AutoCrib
