DIN-rail power supplies for chemical, oil and gas applications
Idec Corporation's PS5R-V line of DIN-rail power supplies are designed for hazardous location applications such as oil and gas processing and petrochemical facilities.
Idec Corporation’s PS5R-V line of DIN-rail power supplies are approved for installation in Class I Division 2 environments in standard control cabinets, making them ideal for use in hazardous location applications such as oil and gas processing and petrochemical facilities. The PS5R-V line of power supplies includes 10, 15, 30, 60 and 120W versions and has a temperature operating range from -25 to 75 C. It also has a small footprint to reduce panel space and reduce installation costs. Flexibility is designed into the PS5R-V line of power supplies with spring-up screw terminals that accept ring and fork terminals, as well as stripped wire. The power supply can also be mounted in six different orientations with minimal derating, which provides multiple configuration options.
Idec Corporation
– Edited by CFE Media. See more Control Engineering energy and power products.
