Digital pH/ORP sensor and PC software platform
Yokogawa's SENCOM platform product series for the digital measurement of pH and ORP consists of a module, a sensor, cable, and software that are designed for process industries.
Yokogawa’s SENCOM platform product series for the digital measurement of pH and ORP is designed for process industries like oil, petrochemicals, iron and steel, electric power, and water supply and wastewater treatment.
The SENCOM platform consists of a SENCOM module, the FU20F pH/ORP SENCOM sensor, a SENCOM cable, and the SPS24 SENCOM PC software. The installation of a SENCOM module in an FLXA21 transmitter will give it the powerful digital signal processing capabilities required to work together with the new SENCOM sensors.
The FU20F pH/ORP SENCOM sensor is a general purpose sensor that is suitable for a wide range of applications. The FU20F can store digital data and be calibrated using the SPS24 SENCOM PC software and/or the FLXA21. With these SENCOM platform products, our customers will be able to reduce the amount of maintenance work that needs to be performed on-site, thereby improving efficiency and reducing costs.
The FU20F pH/ORP SENCOM sensor is able to process digital signals and store digital information, including calibration data. Using either the SPS24 PC software or an FLXA21 transmitter, it can do offline calibration of these sensors in a laboratory, where working conditions are optimal. With the SPS24 software, it will be possible to simultaneously calibrate up to four SENCOM sensors, significantly shortening calibration time.
The SPS24 software features an integrated database capable of storing data for up to 100 SENCOM sensors. This enables predictive maintenance, allowing service staff to identify when sensor maintenance and/or replacement is required. In addition, there is no longer the need to go on-site to obtain the data stored on a converter.
Yokogawa
– See more Control Engineering process sensor and actuator products.
