Digital-based DP level technology for electronic remote sensor systems
The Rosemount 3051S ERS System by Emerson Process Management can replace mechanical impulse piping by linking pressure sensors together, electronically.
SOURCE: Emerson Process Management
Eme
rson Process Management’s first digital DP Level architecture, the Rosemount 3051S Electronic Remote Sensor system can replace mechanical impulse piping with two 3051S pressure sensors linked together electronically. Differential pressure is calculated in one of the two sensors and is transmitted using a standard two-wire 4-20 mA HART signal.
When used in distillation towers and other installations that traditionally have required excessive lengths of impulse piping or capillary, the 3051S ERS System can deliver:
- Improved Performance: The 3051S ERS System replaces mechanical components with a digital architecture, allegedly resulting in faster response time and a more stable measurement even in applications with wide varying temperatures.
- Simplified Installations and Maintenance: Cold weather installations often require heat tracing or insulation. Impulse lines need to be checked for leaks, condensation, evaporation, and plugging. The digital architecture of the 3051S ERS System eliminates these practices.
- Additional Process Insight and Diagnostics: The 3051S ERS System is a multivariable solution that provides additional process information for optimized control. In addition to the DP calculation, the 3051S ERS provides real-time access to the readings from each pressure sensor and a scaled output for tank level or volume measurement.
The Electronic Remote Sensor system is built on the scalable 3051S architecture and is part of a broader portfolio of Rosemount DP level and process level technologies that include Tuned-System Assemblies, radar, ultrasonic, and switches.
