Cutting fluid
Vascomill 10, a liquid tool for high-pressure oil applications, is especially suited for cutting oil applications in Swiss-style CNC lathes. Its low viscosity allows for maximum air escape, making it resistant to foaming. The fluid, a vegetable ester-based cutting oil, pairs its low viscosity with a high flashpoint comparable to mineral oils of the same viscosity.
Vascomill 10, a liquid tool for high-pressure oil applications, is especially suited for cutting oil applications in Swiss-style CNC lathes. Its low viscosity allows for maximum air escape, making it resistant to foaming. The fluid, a vegetable ester-based cutting oil, pairs its low viscosity with a high flashpoint comparable to mineral oils of the same viscosity. Its vegetable-base makes it environmentally conscious. The fluid is suitable for stainless steel, titanium and high-temperature alloys.
Blaser Swisslube Inc. www.blaser.com
