Cordsets for food and beverage applications
The M12 overmolded cordsets are ideal for harsh environments such as demanding vibration and high pressure washdowns.
By Binder-USA August 29, 2016
The M12 overmolded cordsets are ideal for harsh environments such as demanding vibration and high pressure washdowns. The M12 cordsets are suited for the food and beverage, pharmaceutical and chemical industries where a robust washable connector is required. The connectors have a maximum rated voltage of 250 V. The white cable overmold is accompanied with a grey PVC cable and a stainless steel locking nut to ensure durability. To support the robust design, an IP69K rating ensures protection from high-pressure washdowns.
Binder-USA
www.binder-usa.com
