Coolant decanter
A new coolant decanter improves efficiency of parts washers and machine tool coolant sumps by making it possible for coolant to be virtually recycled for reuse. The Mighty Mini SSTweights just seven pounds and is designed for the machine tool industry. Its small footprint is well suited for areas where space is at a premium.
A new coolant decanter improves efficiency of parts washers and machine tool coolant sumps by making it possible for coolant to be virtually recycled for reuse. The Mighty Mini SSTweights just seven pounds and is designed for the machine tool industry. Its small footprint is well suited for areas where space is at a premium. The optional coolant saving decanter separates coolant from skimmed tramp oils, so virtually no coolant is thrown out with the tramp. By lessening the volume of waste, disposal costs can be significantly reduced. Also, each batch of coolant or wash solution lasts longer.
Abanaki Corp. www.abanaki.com/019
