Conveyor systems
Designed for descaling and profiling plate and structural steel, the roll conveyor Shotblast system has been specifically developed to provide surface preparation solutions for the fabrication industry.
Designed for descaling and profiling plate and structural steel, the roll conveyor Shotblast system has been specifically developed to provide surface preparation solutions for the fabrication industry. A continuous controlled-feed of steel into the blast zone results in time savings. An alternative to manual air blasting, Autoblast roll conveyor machines are specifically-designed to descale and remove rust from plate and structural members prior to fabrication. It uses four EZEFIT wheels that blast with steel shot abrasive at a velocity of 265 feet per second.
Wheelabrator Group
