Control Equipment
Photoelectric sensor replaces multiple designs World-Beam photoelectric sensor compactly fits most mounting requirements.
11/01/2000
World-Beam photoelectric sensor compactly fits most mounting requirements. It is available in opposed, reflective, convergent, regular, and wide-angle diffusion sensing modes. The sensor is offered as either sinking or sourcing outputs, and switches loads up to 100 mA while indicating power on, output status, overload, and marginal signal conditions. Banner Engineering Corp.; www.bannerengineering.com
TO VOTE, WRITE 44 ON BALLOT
For more information, circle 44 on card
Temperature control interfaces with PLCs or HMIs
MLC9000 is a bus-based temperature control system that interfaces with programmable logic controllers (PLCs) or human machine interfaces (HMIs) to integrate temperature and machine control. It interfaces with a user-chosen HMI directly or via PLC registers, and communicates directly to the PLC via open buses. Danaher Controls; www.MLC9000.com
TO VOTE, WRITE 78 ON BALLOT
For more information, circle 78 on card
Flat panel monitor displays at extreme viewing angles
Versa Mount 18.1-in. flat panel monitor has a display area equal to that of a typical 20-in. CRT monitor. It adapts to benchtop, arm pendant, and yoke mounting configurations. The monitor features a NEMA 1 enclosure; integrated, 12-vdc, or remote ac operation; and a display resolution of 1280 2 1024 RGB. Intecolor; www.intecolor.com
TO VOTE, WRITE 92 ON BALLOT
For more information, circle 92 on card
Sensor detects objects with widely varying parameters
E67 Long Range Perfect Prox photoelectric sensor accurately detects objects of varying size, reflectance, and color while ignoring background objects beyond the preset target range of 6 ft. It can replace ultrasonic sensors. Dual indicators communicate output and power status. Models are available with both ac and dc operation in a single unit. Eaton Corp.; www.sensingsolutions.com
TO VOTE, WRITE 96 ON BALLOT
For more information,circle 96 on card
Proximity sensor withstands scratching and abrasion
Stoneface inductive proximity sensor provides durability similar to stainless steel face sensors at the cost of standard products. It offers weld-field immunity and is well suited for applications where abrasion is a factor. The sensor is available in embeddable and nonembeddable models, and features a front face made of thermoset plastic. Turck, Inc.; www.turck.com
TO VOTE, WRITE 105 ON BALLOT
For more information, circle 105 on card
Control connectors gain UL listing
Line of control connectors, which includes Mini-Quick, Micro-Quick, and Nano-Quick, provides quick disconnects for sensors, proximity switches, valves, and other industrial control devices. These UL-listed connectors use high-strength copper alloy contacts and polyurethane overmolds. Strain relief design uses graduated windows, minimizing the arc of bend and directing strain away from contact terminations. Hubbell, Inc.; www.hubbell-wiring.com
TO VOTE, WRITE 109 ON BALLOT
For more information, circle 109 on card
Condition monitor diagnoses faults
DLI Watchman DCX Online is an intelligent and continuous condition monitoring system that can check more than 4000 physical inputs from a wide variety of plant and building control systems, as well as diagnose problems and offer solutions. Connectivity options range from simple dial-up networking to advanced virtual private networking through wide area networks or the internet. Predict/DLI; www.Predict-DLI.com
TO VOTE, WRITE 117 ON BALLOT
For more information, circle 117 on card
Communications module connects Ethernet/IP and Profibus DP
The 4204-DFNT-PDPM communications module connects Ethernet/IP and Profibus DP, thereby integrating two industrial automation control platforms. It provides a high-speed client and server connection to Ethernet/IP processors. Data are exchanged between the two protocol drivers via an internal data file. The gateway also has web server functionality. ProLinx Communication Gateways; www.prosoft-technology.com
TO VOTE, WRITE 119 ON BALLOT
For more information, circle 119 on card
Web enabled recorder sends e-mail
The 4100G videographic recorder allows users to view process data through a PC-based web browser. Users access this data using the internet by entering the recorder's IP address allowing observation of the same information available on the local recorder screen. The viewer can review historical data online. The recorder can send e-mails initiated by alarm conditions. Eurotherm Recorders, Inc.; www.Chessell.com
TO VOTE, WRITE 133 ON BALLOT
For more information, circle 133 on card
Nano size programmable controller saves panel space
VersaMax is a palm-size, DIN rail or panel mountable, programmable logic controller that features capacity for 10 I/O points; proportional band, integral, and derivative (PID); floating-point math; subroutines; and serial read/write commands. It supports up to two high-speed counters and features three pulse-width modulated/pulse train outputs. GE Fanuc Automation; www.gefanuc.com
TO VOTE, WRITE 149 ON BALLOT
For more information, circle 149 on card
Small sensor offers extended range
Superprox proximity sensor features a small size and offers the combination of a 12-mm housing and a range of 50.8 mm (2 in.) for the detection of virtually any material. Increasing the range minimizes sensor damage caused by objects striking it because of close mounting requirements. It operates on 12-24-V dc, and has both sinking (NPN) and sourcing (PNP) outputs. Hyde Park Electronics, Inc.; www.hpsensors.com
TO VOTE, WRITE 166 ON BALLOT
For more information, circle 166 on card
