Contactless inductive coupler solutions
The NIC contactless inductive coupler is used for data and energy transmission in high-stress and wear-intensive applications.
The NIC contactless inductive coupler is used for data and energy transmission in high-stress and wear-intensive applications. The NIC series solves issues in the following applications: two PNP switching signals, one IO-Link device, and 8 PNP switching signals.Up to two PNP switching signals can be transmitted via the secondary part NICS-M30-IOL2P8-0,3-RKC4.4T – either from power clamp sets or from two different sensors that are connected via a VB2-splitter.If the primary part NICP-M30-IOL2P8X-H1141 is connected to an IO-Link master, data from measuring IO-Link sensors can be transmitted bidirectionally. The primary part NICP-M30-8P8-0.3-RSC12T works as an IO-Link master.
Turck
