Compressor operates in high ambient temperatures
QSF rotary screw air compressor has oversized coolers to allow operation in 110-F ambient conditions. A triple-lip shaft seal system virtually eliminates fluid leakage. A tangential lubricant separation system minimizes fluid carry-over.
QSF rotary screw air compressor has oversized coolers to allow operation in 110-F ambient conditions. A triple-lip shaft seal system virtually eliminates fluid leakage. A tangential lubricant separation system minimizes fluid carry-over. Gear driven, direct coupled, asymmetrical rotor profiles produce 238-730 cfm at horsepower ranging from 50-150.
Quincy Compressor Div., BF Goodrich; www.quincycompressor.com
TO VOTE, WRITE 153 ON BALLOT
For more information, circle 378 on card
