Compressed air modular piping
AP50 pipes are constructed of aluminum-extruded profiles and feature a square design. Fittings and pipes are joined by clamping brackets that are locked by Allen screws. Pressure tightness is accommodated by traditional O-ring seals. Capable of handling compressed air up to 15 bars, the design allows accessories like outlet ports to be installed in minutes, while the system is under pressure.
Teseo SRL : www.teseoair.com
