Compressed air flow meter
The ST50 Flow Meter provides precision flow measurement to reduce the consumption of pneumatic air, helping manufacturing, assembly and process plants reduce air consumables and the energy required to support compressed air systems.
The ST50 Flow Meter utilizes FCI’s thermal dispersion mass flow sensing technology to provide direct mass flow measurement. The design also provides built-in temperature compensation for reliable measurement over a wide temperature range with almost no pressure-drop. The ST50 is designed for endurance and performance in outdoor and field installation conditions. Its electronics are housed in an all-aluminum, epoxy-coated enclosure that is NEMA 4X (IP66) rated and it withstands operational pressures up to 500 psig [34 bar (g)].
Fluid Components International
