Composite bushing bearing is self lubricating
FluoroNyliner bushing bearing provides smooth, low-friction movement in linear and rotary modes. The bushing does not require lubrication when operating in hostile, contaminated, submerged, washdown, or vacuum conditions.
FluoroNyliner bushing bearing provides smooth, low-friction movement in linear and rotary modes. The bushing does not require lubrication when operating in hostile, contaminated, submerged, washdown, or vacuum conditions. The self-lubricating composite liner is wear-resistant and withstands shock, vibration, and temperatures to 550 F and speeds to 400 fpm.
Thomson Industries, Inc.
www.thomsonindustries.com
