Compact modular valves
The NITRA compact modular valves valves are designed for performance, flexibility and modularity.
July 18, 2014
The NITRA compact modular valves are designed for performance, flexibility and modularity. Each valve is enclosed in a reinforced technopolymer protective shell that acts as a shock-absorber and prevents the infiltration of dirt. All pneumatic connections are on one side, with built-in push-to-connect fittings. The system offers a variety of flexibility from 1-16 valves, with input and output terminals for tubing of different sizes. The 24VDC electrical signal is relayed from one valve to the next by gold-plated contacts so the electrical connections are entirely automatic. CMV series valves are available in four port size combinations, and 3-way/2-position, 5-way/2-position and 5-way/3-position configurations.
AutomationDirect
www.automationdirect.com
