Compact LED solution for demanding environments
The DMW2 LED solution that provides application versatility and energy saving control options for demanding applications where moisture or dust in a concern.
The DMW2 LED solution that provides application versatility and energy saving control options for demanding applications where moisture or dust in a concern, such as food processing plants, loading docks and cold storage. The DMW2’s low-profile design and captive latches makes for more streamlined handling and balancing. The DMW2 is ideal for mounting on ceilings, walls, and pendants. It maintains IP66 wet location listing when wall mounted. It features an integral battery-pack option that eliminates the need for additional emergency fixtures, remote placement, or use of AC power inverters.
Acuity Brands
