Combustible gas leak detector
The PRO-Chek™ CG (combustible gas) Detector provides a safe and effective way to detect gas leaks in industrial systems.
The PRO-Chek™ CG (combustible gas) Detector provides a safe and effective way to detect gas leaks in industrial systems. It is ideal for finding leaks in in natural gas systems, propane tanks, pipelines, regulators and valves, heat exchangers and much more. The unit detects natural gas, propane, ammonia, methanol, ethanol, ethane, butane and other gases. The detector features an adjustable sensitivity control that helps pinpoint the exact location of every leak fast and a variable-intensity audible alarm and flashing LEDs to quickly determine the size and strength of the the leak.
Spectroline
