Combo-tip drivers
The combination-tip drivers are designed for maximum contact with the combination head screws most commonly found on electrical devices and fittings.
The combination-tip drivers are designed for maximum contact with the combination head screws most commonly found on electrical devices and fittings. Available in Fixed-Blade Screwdrivers, Impact Rated Power Drivers and the 11-in-1 Screwdriver, each is custom heat-treated to withstand the torque needed to fasten all types of combination head screws. It is made with steel for long-lasting bit shape and strength. The screwdrivers feature Cushion-Grip handle for greater torque and comfort.
Klein Tools
