Coalescing filters
The coalescing filters protect sensitive pneumatic equipment from the harmful effects of air line contamination.
By Bimba July 1, 2015
The coalescing filters protect sensitive pneumatic equipment from the harmful effects of air line contamination. These filters remove fine oil mist and contamination down to 0.01μ. Fine borosilicate microfibers in the filter media collect microscopic particles while the outer filter drainage layer allows coalesced liquid to fall into the filter bowl.  Available in a variety of sizes, the coalescing filters can be mounted individually or connected to other MFD Filter-Regulator- Lubricator (FRL) components via modular connector kits. Multiple drain styles (including manual, automatic, and semi-automatic) are also available.
Bimba
www.bimba.com
