Clamp-on wrench
The Nut Buddy for socket-cap screws is a knurled, clamp-on wrench that converts any socket cap screw into a large knob, facilitating spin-on and spin-off adjustments. The compact wrench can be hand tightened but allows for conventional wrenches when high torque is required. Featuring an easy-to-grip, knurled outside surface, the Nut Buddy is machined from aluminum, has a round bore to fit socket cap screws ranging from 1/4″ to 1/2” dia. and an anodized finish. It’s also available with a hex bore.
Stafford Manufacturing Corporation www.staffordmfg.com
