Chill out on electric deregulation
A 4-p color brochure describes the "ideal" chiller-plant management strategy in the era of electric utility deregulation: Use electric chillers to take advantage of low off-peak rates and then switch to nonelectric chillers to avoid high-cost peak rates.
A 4-p color brochure describes the “ideal” chiller-plant management strategy in the era of electric utility deregulation: Use electric chillers to take advantage of low off-peak rates and then switch to nonelectric chillers to avoid high-cost peak rates. The brochure advocates mixing electric and nonelectric chillers in a hybrid plant to allow the most economical choice and use of energy sources.
York Intl. Corp.
www.york.com
Circle 269
