Check for corrosive environments
A-Prompt monitor measures atmospheric corrosion on metallic surfaces using a copper-plated quartz crystal microbalance sensor.
By Staff August 1, 1999
A-Prompt monitor measures atmospheric corrosion on metallic surfaces using a copper-plated quartz crystal microbalance sensor. This real-time technology offers users a method of determining the corrosive potential of an environment as it relates to the protection of electronic, process, and motor control systems. The unit installs inside the corrosive-gas removal system, at the outlet.
Purafil, Inc.
www.purafil.com
Circle 271
