Centrifugal screener
The Centri-Sifter MO is a medium-capacity centrifugal screener that features a cantilevered shaft with two externally-mounted bearings between the screening chamber and motor drive.
The Centri-Sifter MO is a medium-capacity centrifugal screener that features a cantilevered shaft with two externally-mounted bearings between the screening chamber and motor drive. The design allows internals to slide freely from the shaft end for cleaning, screen changes, or inspection. Wide spacing between the bearings, a large diameter shaft, and a flexible shaft coupling are incorporated to prevent vibration. Configurations are offered for continuous operation in-line with dilute-phase pneumatic conveying systems, as well as gravity-fed applications.
Kason Corp.
