Centrifugal pump for hygienic pumping applications
EcoPure centrifugal pump designed to increase production efficiency and product safety in hygienic applications such as food and beverage, dairy, and pharmaceutical.
By SPX September 29, 2015
The EcoPure centrifugal pump is designed to increase production efficiency and product safety in hygienic applications such as food and beverage, dairy, and pharmaceutical. EcoPure features drive magnets and impellers with no need for mechanical seals. This helps a plant’s ability to reduce waste water streams associated with seal flushing. The pump uses heavy duty forged and machined wetted components to ensure durability in demanding process environments. Its rigid design reduces maintenance and water usage, provides longer running times, and increases process safety.
SPX
www.spx.com
