Central lubrication
Features and benefits of piston distributor systems for accurate, efficient, intermittent oil lubrication of small to large machines and equipment with up to 150 or more lube points are the subject of a 28-p bulletin.
Features and benefits of piston distributor systems for accurate, efficient, intermittent oil lubrication of small to large machines and equipment with up to 150 or more lube points are the subject of a 28-p bulletin. The literature includes photos, drawings, complete specifications, and dimensions for pumps, reservoirs, controls, manifolds, piston distributors, and accessories.
Lubriquip, Inc.
www.lubriquip.com
