Cart transports and filters oil
The 2000 drum handling filter cart transports a steel 55-gal. drum and filtration/transfer equipment. Equipment includes a 1-hp motor, 5-gpm pump, and 3-micron absolute filter and water absorbing filter, both with visual indicators.
The 2000 drum handling filter cart transports a steel 55-gal. drum and filtration/transfer equipment. Equipment includes a 1-hp motor, 5-gpm pump, and 3-micron absolute filter and water absorbing filter, both with visual indicators. Options include an oil analysis kit for periodic testing for contamination, and water and a drum breather adapter kit with a quick disconnect for oil cleaning.
Y2K Fluid Power, Inc.; www.bcity.com/y2kfluidpower
TO VOTE, WRITE 92 ON BALLOT
For more information, circle 393 on card
